5 members (Otto Skorzeny, Biermann, Ridgeback, Oswald, GMCJammer51), 72 guests, and 1 robot.
Topics128,154
Posts1,056,837
Members48,456
Is there nany way to identify if a stock 6cyl is a 216.5 or 235?mine has stamped on it on the top rim of the block 383716 GM6. I can not find any other numbers.
RB55
Here are locations of various 216/235 casting codes.
head casting code
head date casting code
block casting code
block date casting code
Engine Serial Number
All those codes should allow you/us to ID the size and date.
A quick easy way is to look at the engine side covers to distinguish 216 or 235.
Quote
. . a stock 6cyl is a 216.5 or 235 . .
You have a 3100 1953, the only engine from GM that year on a 3100 was a 216.5
