4 members (klhansen, TooMany2count, Otto Skorzeny, Gdads51), 135 guests, and 2 robots.
Topics128,047
Posts1,055,533
Members48,424
#1124861 09/18/2015 9:27 PM
Their not marked R or L so I'm not sure which goes where. Here's a pic of my best guess:
http://i35.photobucket.com/albums/d...20Pickup/20150918_131943_zps6kewb4tc.jpg
But the door won't close tightly even with new rubber. I've adjusted the striker plate all the way inboard and all the way down. So have I got the passenger plate installed here (driver side) or is there something else I'm missing?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
PathwayRev #1124873 09/18/2015 10:00 PM
Did you test fit the doors prior to applying the door seals?
-Line them up so the lines are level with the cab?
-Front edge of door flush or 1/16" proud of the cab?
-Did the door latch work properly prior to the addition of the door seal?
It works best if you do these things first.
Anywho...
You may actually have the striker adjusted way too far inward. This may seem counter-intuitive, but it happens a lot. Bring it out until it will latch, then move it in until it squishes the seal.
Carl
PathwayRev #1124901 09/19/2015 12:57 AM
Not the best picture but, it looks like the rounded lip on the plate is to the outside. Fuzzy picture "figure 14" From the manual: http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0107.htm
They are Left and Right, Some have a stamp, and some do not
Steve H
