| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | Their not marked R or L so I'm not sure which goes where. Here's a pic of my best guess: http://i35.photobucket.com/albums/d...20Pickup/20150918_131943_zps6kewb4tc.jpgBut the door won't close tightly even with new rubber. I've adjusted the striker plate all the way inboard and all the way down. So have I got the passenger plate installed here (driver side) or is there something else I'm missing?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Did you test fit the doors prior to applying the door seals? -Line them up so the lines are level with the cab? -Front edge of door flush or 1/16" proud of the cab? -Did the door latch work properly prior to the addition of the door seal? It works best if you do these things first.
Anywho... You may actually have the striker adjusted way too far inward. This may seem counter-intuitive, but it happens a lot. Bring it out until it will latch, then move it in until it squishes the seal. Carl
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Not the best picture but, it looks like the rounded lip on the plate is to the outside. Fuzzy picture "figure 14" From the manual: http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0107.htm They are Left and Right, Some have a stamp, and some do not
Steve H
