Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall), 54 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1124189 09/14/2015 8:51 PM
Is there a way to get the speedo out with out taken the ignition switch out? When I put it in, I could not get it turned any way to get it in with out removing the switch. 53 3100 root
root #1124197 09/14/2015 9:14 PM
Good question, I was getting ready to do mine too!
root #1124251 09/15/2015 2:24 AM
Even if you could, it is much easier to do it with the switch removed.
root #1124314 09/15/2015 4:01 PM
I've had mine out many times and have not had to pull the ignition housing.
But I don't have a radio or speaker
I do have an electric wiper , but its not n the way.
I remove the speaker grill to get my hand back there
and the choke cable.
I also added some 10/32 knurled nuts, a recommendation found on this forum
...pic...
..spare speedo pic...
Don't have to mess with any sockets or extensions
DADS50 #1124329 09/15/2015 5:48 PM
Best under dash tip of the century, right there.
If those nuts cost $10.00 each, I would still use them!
Carl
root #1124705 09/17/2015 8:23 PM
Dads50
where did you find those nuts?
looks like a headache and a knuckle saver
just-a-hacker
'49 3100 before '99
root #1124710 09/17/2015 8:57 PM
I picked those up at lowes.
Hardware section
DADS50 #1124712 09/17/2015 9:16 PM
great ,thanks
just-a-hacker
'49 3100 before '99
root #1124849 09/18/2015 7:51 PM
Since my glove box crumbled to dust. I just reach in to remove the "grill" part. Then the speedo is right there. Same as Dads50. Use a nut driver and pull the battery. Easy. I do like them nuts, and they are at the local hardware store. Good tip. Undo the battery. Just a simple thing, with peace of mind.
Steve H
Steve_H #1125064 09/20/2015 12:25 AM
Always a safe thing to do. I also agree with those nuts.
root #1125814 09/23/2015 6:25 PM
Been laid up so just getting back. I have a grill and speakers and radio so I will remove the switch and go from there when I can get back to working on the truck. Hope to get back on it in about 1 month. Thanks for the help. root
Moderated by  ndkid275, Phak1
