8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
38
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Is there a way to get the speedo out with out taken the ignition switch out? When I put it in, I could not get it turned any way to get it in with out removing the switch. 53 3100 root | | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | Good question, I was getting ready to do mine too! | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Even if you could, it is much easier to do it with the switch removed.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I've had mine out many times and have not had to pull the ignition housing. But I don't have a radio or speaker I do have an electric wiper , but its not n the way. I remove the speaker grill to get my hand back there and the choke cable. I also added some 10/32 knurled nuts, a recommendation found on this forum ...pic... ..spare speedo pic... Don't have to mess with any sockets or extensions | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I also added some 10/32 knurled nuts, a recommendation found on this forum Best under dash tip of the century, right there. If those nuts cost $10.00 each, I would still use them! Carl
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Dads50 where did you find those nuts?
looks like a headache and a knuckle saver | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I picked those up at lowes.
Hardware section | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Since my glove box crumbled to dust. I just reach in to remove the "grill" part. Then the speedo is right there. Same as Dads50. Use a nut driver and pull the battery. Easy. I do like them nuts, and they are at the local hardware store. Good tip. Undo the battery. Just a simple thing, with peace of mind.
Steve H
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Always a safe thing to do. I also agree with those nuts. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Been laid up so just getting back. I have a grill and speakers and radio so I will remove the switch and go from there when I can get back to working on the truck. Hope to get back on it in about 1 month. Thanks for the help. root | | |
