2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Hello folks. I have a 1952 GMC 3/4 ton pickup truck with the 8 lug wheels. I need brake drums because mine are totally worn out and unusable.
I can find 6 lug drums all day long. No one makes an 8 lug drum that I can locate. Centric SAYS they have one, but when I ordered it, it's an inch too big. It's supposed to measure 11 inches and what they sent was 12 inches.
I desperately need brakes. Am I going to be force to switch to a different bolt pattern just because of a lack of parts? Or is there a company someone knows about out there that sells the PROPER size 8 lug drums?
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think turning used ones have been the only option for a long time. Occasionally NOS ones appear on eBay. A 52 Would still have Huck Brakes. Getting a backing plate from a 53 to 59 will give you Bendix brakes and parts for them are much more available. You would still use your 8 hole wheels. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | My original brake drums are about shot. One is shot. It is actually cut in half.
There was a guy I remember, if I could find his number... He was in Denver and had a huge store of used truck parts for the AD series. I used to buy stuff from him all the time. That might be my only chance.
Maybe I could either buy the '53-'59 backing plate, or I could buy the '52 8-lug drums if he has either. And Ebay is a good idea, I'll check there too.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | This is actually a pretty good idea...but it's a lot more than the standard brake job I was thinking of. A couple of hundred...maybe. But a grand is steep for my budget right now. http://www.brotherstrucks.com/prodinfo.asp?number=DBC8L20
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Hmmm...that last disc brake conversion kit is not for my year of truck.
I did find the part number of the drums that I need. The original part number is 3847128.
It is out of production, so my only chance to find one is if I get very lucky, or I find a used drum that can be cleaned up. So the search is on.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Those early AD 3/4-ton front drums are the holy grail. Next to impossible to find Dad. I got lucky a few years back and found a pair of NOS 3847128 drums, Hope they'll last me another 27 years. http://www.pbase.com/dennygraham/image/160723376 Like to hear more about this Bendix conversion for the 3600 Ken. Will those backing plates just bolt up to the early steering knuckles? The original reason for doing this was because the drums were shot. How bout the drums for the Bendix brakes, is the bearing spacing, diameter, seals and all that the same as the Huck brake??? If it were, why couldn't you simply use the later drums with the Huck brakes??? They should both be 11". Seems to me like there are a few of those tiny details missing for a Huck to Bendix conversion. dg
Denny G Sandwich, IL
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Wow Denny those drums were quite a find. I had one good turn left in mine. After that it's replacement time.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes they were, din't come cheap and had to get them shipped up from South America, took almost a month and wasn't sure they would make it right up till UPS dropped them off.
I've been in the process of restoring a large 16" Lodge & Shipley engine lathe for some years now. If I ever get it finished it's big enough that I can do some experimenting with welding original centers into later drum rims. It's one of those projects that I'd like to do some experimenting with since the supply of early 3600 drums are pretty much run it's course. DG
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I think it would be a whole lot easier to convert fronts to disc, others here have done conversion.
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Denny you hit the thought I had. Why couldn't someone, not me I don't have the resources to do it, weld a round steel band inside a drum and then turn it? Breath new life into the drums no longer available.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...sleeve and engine, why not sleeve a brake drum, eh. Makes sense to me. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not on my watch Alvin. with the heat generated in a drum brake and the different coefficients of expansion of steel and Meehanite cast iron, welding a liner in a drum would be a disaster waiting to happen.
Appears to be some confusion as to what I was talking about. I did not mean weld a steel lining in the cast drum. This whole idea was just a passing thought, something like gas, you know. What I meant was to swap centers with a later model drum and it was just a thought. I really haven't delved into this very deep, got enough projects going on right now and I'm not in need of brake drums at this time. With out having an early Huck drum and a later Bendix drum on the table in front of me to compare, it's hard to visualize just where the problems lie. If it's just a width problem then it may be possible to face the drum down to the narrower width if there were enough thickness. If it's an offset problem then the only solution would be to cut out the center from both and weld the old center into the new drum. This would have to be done on the steel center, not on the cast drum rim. I've never been able to find any information on how two piece drums, that is, cast/steel are made but I think the steel centers may be cast or potted into the drum at the time they are poured rather than welded together. When you look at the joint of a cast drum/sheet steel center it appears by the step that there was a lot of material machined away before the finish diameter was reached.
Any way you look at it, this would be a major project that would involve a LOT more engineering and tooling than I'm capable of or would feel safe with.
DG
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Old Buick drums are sleeved frequently. There is a local guy that does this. They insert a new steel band into the aluminium drum. They were never meant for this to be a repairable part. Used on hot rods all the time. It is a high heat process. Just FYI.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Never heard of that Bruce, thanks. Thought Jerry, with his vast exposure, would jump in on this discussion to fill in the blanks. Seems kind of odd that they would use a steel sleeve in an aluminum drum with the large spread in the expansion coefficients of each. That becomes especially problematic when you're talking about a ring that is 10", 11", 12" or what ever their drum diameter is.
Think I'd feel more secure with old school two piece or single piece ferrous drums. But....you know me, I'm not a hot rodder. And obviously I'm not up on the latest automotive repair procedures. However, I am always willing to learn something new. After googling "Aluminum Brake Drums" I see now that they are not at all that unusual.
Enough of this silliness.....I'm gonna go out to the barn and do some real work. DG
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | The only thing that really concerns me is how to prevent the welded two-piece drum that you end up with, from being out of round. I mean, it's going to have to be gnat's-ars perfect or it won't work.
I thought about trying to see if Centric or one of these other drum manufacturers would consider drilling one of their 11" drum blanks with 8 lug holes instead of 5 or 6. That right there would solve the problem nicely. However, considering that they now get their drums from China, I don't know if I'd put my money on a Chinese custom-job. I just don't have that much confidence in the Chinese.
My best chance at solving this problem is to find another 8-lug drum at a salvage yard, and hope I can get the darn things apart.
I did, however, find a '60's GMC 3/4 ton 2WD truck in the salvage yard here locally, and it has...(drum roll please)...a bolt-on crossmember on a narrowed front frame with DISC BRAKES on 8 lug wheels!!!
I might have to drive on three brakes instead of four, and do a lot of downshifting, but if I buy that front clip and spend the winter restoring it, that might be my best bet. Unfortunately, returning my '52 GMC back to stock front brakes is kind of impossible if you can't even get restoration parts. There's all kinds of stuff for half-tons, but almost nothing for 3/4 tons.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Those early AD 3/4-ton front drums are the holy grail. Next to impossible to find Dad. I got lucky a few years back and found a pair of NOS 3847128 drums, Hope they'll last me another 27 years. http://www.pbase.com/dennygraham/image/160723376 Like to hear more about this Bendix conversion for the 3600 Ken. Will those backing plates just bolt up to the early steering knuckles? The original reason for doing this was because the drums were shot. How bout the drums for the Bendix brakes, is the bearing spacing, diameter, seals and all that the same as the Huck brake??? If it were, why couldn't you simply use the later drums with the Huck brakes??? They should both be 11". Seems to me like there are a few of those tiny details missing for a Huck to Bendix conversion. dg Later drums with huck brakes. I actually considered that. I found a drum, 11 1/8" diameter, on 8 lugs on Ebay. Problem was it was a half inch too deep, and the guy wanted almost $200 for it. It might have worked, but $200 with a no-return policy, still needing machine work to cut 1/2" off around the rim to reduce the depth? I thought I'd keep looking.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I bought an extra set of front drums off a fellow here awhile back. They do not match mine so I'd be willing to let them go. If you want to private message me the measurements on yours I can check these and send you pictures.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | However, considering that they now get their drums from China, I don't know if I'd put my money on a Chinese custom-job. I just don't have that much confidence in the Chinese.
. As much as I hate to say this, the Chinese actually do a very good job of casting iron. The trick is that you have to specify exactly what you want, because that will be the spec they make it to. With the experience I've had dealing with late models, and using rotors cast here, Brazil, Mexico, Canada, and China, the Chinese drums and rotors seemed to be at least as good of quality as the US, Canadian, and Brazilian made parts, and in some cases, surpassed them, and far surpassed the Mexican made parts. I've actually had to machine a new rotor made in Mexico because it was so far out of spec for runout, never had to do that with a Chinese version of the same part. Also, consider the fact that the Chinese were casting iron when the Europeans were still trying to figure out Bronze.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have converted Huck to Bendix but its been years. It wasn't that complicated and it was before I had all the shop equipment I now have. I think it was a simple matter of drilling 5/16 holes to accommodate 3/8 bolts. Lots of 3/4 tons get scrapped. It is worth looking at old 3/4 tons. A few years ago a friend of mine discovered almost new drums on a 3/4 ton cut off and made into a trailer. Making trailers out of 3/4 ton used to be popular because of the full floating axles and the possibility of either 15" or Ford 16" wheels. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I bought some Raybestos drums for a 54 GMC and a 56 Ford Passenger car. They are all made in China. I will not install any more Chinese drums on my semis. I bought a pallet of them from International with International part numbers. About 25% of them broke to pieces which is not only a dangerous situation, but also a DOT out of service. I don't need points on my CSA 2010, nor do I need to pay tow charges for red flagged vehicles. Fleetpride made me a deal on 6 pallets of Centrifuse drums. They cost 3 times as much as the Chinese junk, but we haven't had a single failure. And we are hard on brakes. Grossing 84,000 on 5 axles and a lot of stopping in the metropolitan San Antonio area traffic. I would strongly consider used drums. These guys cut a lot of old 3/4 ton pickups. http://rpmclassicparts.com/I would give them a call. I have bought quite a bit of stuff from them. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I've swapped my rear end for a Ford Dana 60 a few years ago, so that should be a little easier to find parts for.
About the only chance I've got on my front brakes is to either scour the salvage yards for 8-lug drums and hope I can get them apart, or convert to newer brakes. (Or both).
I don't understand why the aftermarket concentrates on the half tons but almost nothing is available for the 3/4 ton.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I bought an extra set of front drums off a fellow here awhile back. They do not match mine so I'd be willing to let them go. If you want to private message me the measurements on yours I can check these and send you pictures. PM sent. Thank you.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I did apparently find an old 3/4 ton brake drum at RPM Classic Parts. They want $45 for the drum, plus whatever shipping it is. A reasonable deal, provided the drum is still in good condition. Hopefully once I get it, it will fit.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have bought quite a bit of hard to find stuff from RPM and it was always better than what I expected. I hope you have the same kind of luck with them that I have. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I just can't believe how hard it is to find restoration parts for a 3/4 ton. I'll bet most people convert to 5 or 6 lug wheels just because you can find plenty of stuff for that. But in all these years, no one can step up and produce 3/4 ton parts...unless it is shared with the half tons?
...Why?
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | There simply aren't that many 3/4 ton trucks that are being restored, everyone wants 3100 five window trucks. Isn't worth tooling up for a small market such as the 3600. I've been trying for a decade to get someone interested in making a run of 3.90 gears for the HO52/72 rear axle but there again, not enough to justify making a batch of them. There certainly is a market for 3600 hard to find parts, all we need is someone with the manufacturing skills to pick up on it.
dg
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I ran into that problem when I needed a rear main bearing set for a Chevy big block with the thicker thrust flanges, like you used to always be able to get. The part number is still active, but unless they get at least 100 orders, they won't send it in to have a batch made.
Might be something like that.
This is why I finally broke down and replaced my original rear end with a Ford Dana 60. Other than the lack of a posi, it is nice to have a 3.50 gear set back there! I actually have highway legs now.
I think if you have a 3600, you're almost forced to restofy instead of restore.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not so "ke-mo sah-bee"! I've been driving a bone stock '50, 3600 since 2005 and put several thousand miles on it each year. Been able to fix, repair, replace, rebuild everything on it so far. Just takes a little extra effort.
dg
| | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | The only reason I bought my Howard Knapp truck because it was cheaper than any other AD style truck but it was 1 ton...so it sorta looked like a 1/2 ton....the very first thing I had to do was literally cut two of the four stock 8 lug drums off with a cut off wheel due to broken brake springs...that started the swap that I did not want to do...I pulled the 8 lug rear end out and put a 6 lug K5 Blazer rear end in and then I went up front and yanked the whole front end out...springs....hangers...axle...spindles everything and mounted a 1/2 ton 6 lug front end under it...I did a disc brake upgrade for less than $1000.00. The rear end swap I think was less than $250.00 with used 1999 Chevy rear truck springs and new (Speedway Motors) spring perches....in end now I have now is like a heavy 3/4 ton truck...and I can get over the counter NAPA type parts for the truck...
I have not run this rig yet so I am really praying that all this work will work in the end...
My 2 cents...
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Oh, modifying the 3/4 ton to make it safer and easier to get parts for does not bother me. It's just sometimes what you have to do. I did actually find a drum for it, and I paid for it...but have not even received confirmation that they got my payment or are sending the part.
This is RPM Classic Parts. So I need to check on it and make sure I didn't just pay for "air".
