| | | Forums66 Topics128,125 Posts1,056,339 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 16 New Guy | | New Guy Joined: Feb 2014 Posts: 16 | have a 1957 3600 chevy truck ?? want to drop wheel size and lug pattern down to 5 ??? can I just swap the 5 lug hub for the 6 lug or 8 lug ones or do I have to swap complete axle or are just the spindles interchangeable ????? ,,,,, someone must know ?? ha ha ha maybe not cheers in advance for all answers
| | | | | Joined: Feb 2011 Posts: 12 New Guy | | New Guy Joined: Feb 2011 Posts: 12 | on my 50 the easy way was to get a 1/2nton axle, it was a direct swap, they even use the same springs. Not sure if that is true in 57, but the spindles and axles are not the same 1/2 ton to 3/4 ton for sure. If this is the route you want to go put a wanted to buy ad on craigslist- there are a lot of people swapping to independent front ends who will let their original go for a reasonable price. | | |
