3 members (Bill Hanlon, baldeagle, Ponchogl), 59 guests, and 10 robots.
Topics128,020
Posts1,055,345
Members48,420
Gas Pumper
Gas Pumper
I was sitting with Jim Carter at the KC Reunion and we were talking about spin on oil filter adapters. I showed him what I came up with that uses the side mounting triangular bosses. I said... "the problem is, it only works with 58-62".
He says... "the side mount bosses came out in 1952 on passenger cars. In 1954, there was no truck vs car engines. For that year, cars and trucks use the same engine, so the cars and trucks of that year have triangular side mount bosses."
He had me walk over to a 54 with original engine to verify. Sure enough. Does this sound right? I am working on a bypass spin on solution using the Trans-Dapt 1028 with a 1/16" reducer in the line. Would be nice to verify who I could suggest this modification to. Any comments on the best place to put this reducer? IN or OUT? Make any difference?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Hey Deve, any luck with getting Grigg to let you duplicate his slick mounting bracket?
Allen
1974 Stingray Corvette
Gas Pumper
Gas Pumper
Grigg will correct me if I am wrong, but yes, he didn't want to do them for a living, so I offer them as an alternative to mine. His was ingenious! One piece of metal and 6 holes. If you have Fenton dual exhaust manifolds on your rig, that plate is a necessity. Then for the normal setup with a Generator, you want to run the original one so as not to invade the Generators territory. People with Alternators get their choice. Thanks to Cosmo too for sharing it!
Deve
The Think Tank
ODSS President
ODSS President
Deve, just received my "bomb-proof" Alan Grove alternator bracket kit. Beautiful, made in U.S. Will take a picture if interested.
~ Cosmo
1949 Chevy Half Ton
I would reduce the oil line on the way out, that way bigger chunks of dirt will make there way into the filter.
I know nothing that big is in the oil, but, it sounded good!
Joe
All of the AD truck engines which I have seen have the side mount bosses. They are drilled but not tapped.
Carl
Gas Pumper
Gas Pumper
Always interested Cosmo! Great idea Joe. That pretty much resolves that.
Now, for those who do not have that triangular boss on the side of the engine for side motor mounts, I am always up for suggestions on where to put a bracket. What comes to mind is to drill two 3/8" holes on the bottom of the C-Channel (Frame) right across from where those triangular bosses are supposed to be. Install the Trans-Dapt 1028 with reducer, then plumb it with braided stainless steel oil line hose using AN to NPT fittings. By using this flexible oil line, it will not be affected enough to matter by the engine moving around a little. Does this sound right?
Deve
The Think Tank
What year/CID engines don't have the side motor mount bosses?
Gas Pumper
Gas Pumper
To answer my own question, 3836235 which is a 1955-1957 235 does not have the triangular side motor mount bosses. If anyone has other numbers to add to this list, please do so. Thanks!
Deve
The Think Tank
