| | | Forums66 Topics128,087 Posts1,056,375 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I was sitting with Jim Carter at the KC Reunion and we were talking about spin on oil filter adapters. I showed him what I came up with that uses the side mounting triangular bosses. I said... "the problem is, it only works with 58-62".
He says... "the side mount bosses came out in 1952 on passenger cars. In 1954, there was no truck vs car engines. For that year, cars and trucks use the same engine, so the cars and trucks of that year have triangular side mount bosses."
He had me walk over to a 54 with original engine to verify. Sure enough. Does this sound right? I am working on a bypass spin on solution using the Trans-Dapt 1028 with a 1/16" reducer in the line. Would be nice to verify who I could suggest this modification to. Any comments on the best place to put this reducer? IN or OUT? Make any difference? | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Hey Deve, any luck with getting Grigg to let you duplicate his slick mounting bracket?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Grigg will correct me if I am wrong, but yes, he didn't want to do them for a living, so I offer them as an alternative to mine. His was ingenious! One piece of metal and 6 holes. If you have Fenton dual exhaust manifolds on your rig, that plate is a necessity. Then for the normal setup with a Generator, you want to run the original one so as not to invade the Generators territory. People with Alternators get their choice. Thanks to Cosmo too for sharing it! | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Deve, just received my "bomb-proof" Alan Grove alternator bracket kit. Beautiful, made in U.S. Will take a picture if interested.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Feb 2000 Posts: 5,225 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,225 | I would reduce the oil line on the way out, that way bigger chunks of dirt will make there way into the filter.
I know nothing that big is in the oil, but, it sounded good!
Joe | | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | All of the AD truck engines which I have seen have the side mount bosses. They are drilled but not tapped. Carl
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Always interested Cosmo! Great idea Joe. That pretty much resolves that.
Now, for those who do not have that triangular boss on the side of the engine for side motor mounts, I am always up for suggestions on where to put a bracket. What comes to mind is to drill two 3/8" holes on the bottom of the C-Channel (Frame) right across from where those triangular bosses are supposed to be. Install the Trans-Dapt 1028 with reducer, then plumb it with braided stainless steel oil line hose using AN to NPT fittings. By using this flexible oil line, it will not be affected enough to matter by the engine moving around a little. Does this sound right? | | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | What year/CID engines don't have the side motor mount bosses?
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | To answer my own question, 3836235 which is a 1955-1957 235 does not have the triangular side motor mount bosses. If anyone has other numbers to add to this list, please do so. Thanks! | | |
