| | | Forums66 Topics128,203 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I've searched and read multiple threads but never really found an answer. I have a 54 235 with narrow pulleys on the water pump and alternator. The crack pulley belt groove is wider, so the V-belt rides on the shaft and squeels like a pig. I've been looking and cannot find a 235 crank pully/harmonic damper with narrow belt for less than a house payment. Am I overlooking something easy? I only need one belt groove.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A 1953 and later truck (and, maybe, car) pulley would work.
I think the diameter of some pulleys are different (some car 235s) but that might not be a big deal. Pre '68 Dave would know. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1953-54 car or truck balancers would be best, but an acceptable substitution is to use a 1955-62 truck balancer. The 1955-62 truck balancer is designed for a ½” belt but may be used with a â…œ" belt. This will allow the belt to run deeper in the groove and in effect will reduce the diameter to very near the correct size. The 1955-62 passenger balancer is also designed for a â…œ" belt, but because of the larger diameter there is a increased risk of the fan breaking from the high speed flexing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Thanks guys! I'm looking at the DamperDudes site and they have two listed, one with crank starter and one without. I do not know what they mean. I have the foot-stomp starter on my truck.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Chad M,
My guess is that the "crank starter" means there are fittings on the front of the balancer for a hand crank (that would be on a pre-54 balancer, I think). | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | Chad,
May have what you need. Sent a PM.
Mine are large diameter, 3/8 belt.
Paul | | |
