5 members (klhansen, mick53, Otto Skorzeny, Hotrod Lincoln, 1 invisible), 99 guests, and 3 robots.
Topics128,127
Posts1,056,675
Members48,450
I recently took my radiator to get it cleaned, but they said it had massive leaks and would need a new core at $450, or new radiator for $895. I looked on e-bay and saw a new 3 row aluminum radiator for $199. It looks just like the original, but says the top inlet is 1.5" and the lower outlet is 1.75". My radiator inlet measures 1.25" and the lower is 1.5". I will need to call them to find the differences. Does anyone have any experience with these or other ideas for replacement?
Steve
Don't know about that ebay item, check country or origin.
I've had good luck with U S Radiator
...link...
...link..
I too, recently replaced a 1946 Chevrolet 1/2 ton pickup original radiator with a new one from US Radiator. Great price, quick ship and awesome product. Truck temp runs 170 -180 consistently.
Thanks for your input. I have a new radiator ordered from US Radiator.
Steve
They are the best solution that we have today, i.e., US Radiator.
But, not perfect. Three complaints that I have are:
1st. The lower tank is not the same shape as the original
tank. If you use the crank to turn your engine during tune-ups
the bottom tanks are straight across and block the path. You
will no longer be able to use a crank.
2nd. The upper tank is not the same shape as the original tank.
Additionally the top of the new radiator will set lower in
the core support than an original tank.
3rd. The support brackets were not a good fit to the original
core support holes and were not soldered on the core straight.
I had to open up a couple of holes to make it fit.
As with the Chinese made items, just a little more effort
with their tooling and assembly fixtures and they would
have a perfect replacement part.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Gas Pumper
Gas Pumper
I had the same problems minus the holes. They aligned okay. What I didn't like was that the filler neck follows the contour of the top of the radiator as opposed to being flat and straight. But what a wonderful radiator! With the updated core I won't have cooling problems for a very long time!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
