| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 25 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 25 | I recently took my radiator to get it cleaned, but they said it had massive leaks and would need a new core at $450, or new radiator for $895. I looked on e-bay and saw a new 3 row aluminum radiator for $199. It looks just like the original, but says the top inlet is 1.5" and the lower outlet is 1.75". My radiator inlet measures 1.25" and the lower is 1.5". I will need to call them to find the differences. Does anyone have any experience with these or other ideas for replacement?
Steve
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Don't know about that ebay item, check country or origin. I've had good luck with U S Radiator ...link... ...link.. | | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | I too, recently replaced a 1946 Chevrolet 1/2 ton pickup original radiator with a new one from US Radiator. Great price, quick ship and awesome product. Truck temp runs 170 -180 consistently. | | | | | Joined: Nov 2007 Posts: 25 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 25 | Thanks for your input. I have a new radiator ordered from US Radiator.
Steve
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | They are the best solution that we have today, i.e., US Radiator. But, not perfect. Three complaints that I have are: 1st. The lower tank is not the same shape as the original tank. If you use the crank to turn your engine during tune-ups the bottom tanks are straight across and block the path. You will no longer be able to use a crank. 2nd. The upper tank is not the same shape as the original tank. Additionally the top of the new radiator will set lower in the core support than an original tank. 3rd. The support brackets were not a good fit to the original core support holes and were not soldered on the core straight. I had to open up a couple of holes to make it fit. As with the Chinese made items, just a little more effort with their tooling and assembly fixtures and they would have a perfect replacement part. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I had the same problems minus the holes. They aligned okay. What I didn't like was that the filler neck follows the contour of the top of the radiator as opposed to being flat and straight. But what a wonderful radiator! With the updated core I won't have cooling problems for a very long time! | | |
