0 members (),
85
0
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | My shop is an old 40x80 Farmlander slant wall steel building from the early 1970's. It has a concrete floor that saw several decades of farm implement storage and repair, so there are more than a few scratches and stains on the concrete.
I have cleaned the stains (mostly hydraulic oil drip stains) as best as they can be and I have filled the deep scratches with concrete patch/leveling.
So I am ready to put some sort of finish on the concrete to seal it. I plan to do the front half, a 40x40 area, first because it is the shop area where I am working on my '53 truck.
Anyone have an preference, suggestions or experience on products to use to finish the concrete. I'm looking for a durable surface that spills won't soak through and that can be cleaned.
Thank You Tim
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | The machine shop I go to used Sherwin Williams on his floors, very durable
i tried Sears concrete paint a few years ago, it didn't hold up and now I have to try to resand whole floor. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Epoxys are nice but I'd stay away from them. Aside from being expensive, they require a good sound slab with a lot of prep ( patching, grinding, cleaning ). If you don't do it right, they fail. I'd use a good quality concrete paint, and expect to redo it in 5 years. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I have been watching home improvement shows where they just polish the concrete. I wonder what they use and how much maintenance would be required. | | | | | Joined: Aug 2001 Posts: 3,599 Moderator | | Moderator Joined: Aug 2001 Posts: 3,599 | Sorry guys, I guess I'm old school. It's a work shop with floor jacks, hammers, grinders, cutting torches and other emplements of distruction. I throw some wood stove ashes to soak up the spills and use a good stiff broom to sweep up. If you want a show place, paint it with something, then pour another pad somewhere, to do real work.
Just my opinion. Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now there's a man after my own way of thinking. Fancy floor finish is like those fancy paint jobs, look great but not very practical when you're running down a gravel back road. When I worked at the Accelerator Lab in order to get rid of access budget....the powers to be elected to have the floors ground and epoxy coated. Looked great...for a little while. Then after running the steel wheels of the die carts and gantry cranes over it for a few months it was cracking and lifting all over the place. The other down side is the slightest bet of water made it feel like the neighborhood skating pond in the middle of winter. I like to have the floors look "nice", not fancy, just nice mostly because it seems easier to sweep. So I've just scrubbed them down and hosed them off and roll on a single coat of Rust-Oleum Epoxy Shield one part paint. Not sure if they are even offering that paint anymore, a couple of years back, when I first moved in to the new place it was only bout $30 a gallon. http://www.pbase.com/dennygraham/image/161235728 My welders, gantry and a couple of carts have steel wheels and it stands up pretty goot to them. And, as the other Mr. Graham suggested, I'll just touch it up or repaint it every 5 or 6 years. dg
Denny G Sandwich, IL
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | As others have said, epoxy tends to crack out after a while. The best finish I have seen to date is just a plain old concrete seal. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Well, have you ever seen an Air Force Machine Shop? You can eat off the floor. Epoxy painted floors throughout. All you have to do at the end of every day is allot the time you need to clean the shop. But truth be told, my Dad wouldn't work at my shop because of that. He didn't want to clean up his own mess.
I get lots of stuff done on a daily basis and everyone comments on how neat and clean it is. Shiny floors would add to that ambiance! I use cement sealer but I wonder if wax and a floor buffer once a month or so would make enough difference to go to the trouble. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Denny, probably used the same Rustoleum Epoxy as you mentioned on my floor back when I built my new shop in 2005. Before I put anything in it I painted the floor mainly because I do, or use to, do a lot of wood work and its nice to be able to sweep the floor clean vs the porus concrete. What I found out is its nice to have a spill on the floor and be able to wipe it with a rag and the floor is still clean. I have always hated creepers and now I just lay on the floor. ......my little short wife even bought me a big rubber maid mop bucket with a big mop.....YES, I have pour purple power on it and mopped it a time or two. I like my area clean and when I finish working on a car things are cleaned up before another comes in. I think it goes back to my days, when I was a young teenage having to work on my hot rods laying in the sand and rocks and I always said I'd have me a nice clean shop someday....and after working with only a 1/2" 9/16th 3/4" along with a screwdriver and pair of pliers I swore I have some decent tools someday. YES, they are clean and organized in my tool box. Call me OCD or just call me Strange.... its the way I am  oh, it has held up well. I do have "spots" from welding and other things but I never regretted painting. I could touch up some spots....maybe one day.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "... home improvement shows where they just polish the concrete"
that would be 'high pressure' concrete, a special mix to be chemical/acid resistant, like used for gas station aprons
Bill | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | aha! I didn't know what it was. Thanks! | | | | | Joined: Aug 2013 Posts: 19 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 19 | Anybody know how long a newly poured floor would need to cure before painting? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I do not remember the length of time but it is usually noted on the paint can. I "believe" it to be 7 days. I'm sure someone will chime in with a definite answer. | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | When I was tiling floors it was recommended to wait 30 days before setting tile on green concrete. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Kept the floor wet for about a week after the pour, then dried it about a week, acid etched and pressure washed it and let it cure for another month. Then applied three coats of 2k polyurethane and it stood up to 27 years of use while it was under my care. But....as I said, when it was wet it could have been mistaken for a skating rink. Actually stood up to the steel wheels of the floor jacks pretty good. But around the wood stove where I split wood, it did get pretty well chewed up from flying wedges. dg
