11 members (Gdads51, Gray_Ghost, Woodcmiami, Shaffer's1950, Nick in Manitou, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, 2 invisible),
84
Mod | | | Forums66 Topics128,131 Posts1,056,372 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I searched old topics but I don't think I found a clear answer. How many of the support rod/brackets came in the Suburban, specifically the 1951 model. These are the brackets that go above the headliner material and support the material by means of split pins. So all that is visible inside the cab is the button head.
I'm pretty sure I had all of the fallen headliner pieces when I got my project and there were only three brackets there. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark, Send a PM to KCMongo. He sells a replacement/reproduction set of those strips and split pins. His set/parts look very nice. https://www.stovebolt.com/ubbthreads/ubbthreads.php/users/335.htmlDoes anyone know if those strips/pins were used on all 47-55 years' Suburbans (GMC & Chevrolet). Has anyone found a listing of those parts in a Master Parts Book. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Thanks Tim. I saw that when I researched the old threads. I will keep Mongo in mind if my headliner requires more than the three I have. I looked through the assembly manual but found no document, suburban, truck or otherwise. If I have time today, I'll see if I can dig through the Master Parts Book.
I would guess that the headliner offered by Jim Carter and others WOULD NOT have the holes pre-punched? I would base my guess on how others have had to fit and trim their purchase ( as an example, when Weeds bought and installed his.) Otherwise, that could pretty much show how many were required. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark,
Please take photos of what you do.
I have no idea how you would know where to make the holes for the "pins".
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I will. I still have a ways to go, paint the walls and little parts. Doing a lot of patching and paint removal right now. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I am starting to entertain the idea of using .090 ABS sheet with haircell finish on one side instead of the available cardboard versions. Thoughts? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Mark, I have limited experience with the ABS but with what little I do know I think you'd like it? Sure would last a long time and look kool. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I'll have to wait and see but I don't think I'll need any additional support. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | very nice job. Thxs for the pic's
52 suburban 48 Palace
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Absolutely beautiful, Mark
You ought to be satisfied with the job.
Would you please post information on the material you used? If there is an on-line vendor, would you please post the name of vendor and product, and the Internet link?
Your efforts and results should guide and inspire many people in the future.
I have to replace my warped and poorly cut 12-year-old headliner (from JC) and I have been putting off installing the replacement set. The replacement set will now become my rough-patterns to make good patterns for making the final cuts.
Congratulations and thanks very much. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Thanks Tim. The material is an .090 black ABS, haircell pattern one side, smooth on the other. My job required 3 ea, 4' X 8' sheets. The local shop could cut it down, but they would charge me for the cuts and wouldn't sell a partial. So I just took the whole sheets. Figured I can make side and door panels, maybe even back door panels with what is left over. There are plenty of online sources: http://www.sdplastics.com/abs_extruded_sheet.htmlhttp://www.usplastic.com/catalog/item.aspx?itemid=23013But I found it was much cheaper to source locally. Almost 1/3 the price. And, double the cost to add the shipping for the online sources. The headliner has been in place for a coupe of weeks now. With the change in temperature, I have noticed no changes/sags or any trouble. I also put over three hundred miles on the Suburban and everything stayed in place. I'm still happy with the job and have received a lot of compliments. | | |
