| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I have a 1956 Chevy 3100 and my question is... the upper door hinges are the same for both doors. I called the parts house and they said there is only one hinge for the upper and lower and there is no right side or left side hinge. If this is true the spring on each upper hinge on the one door will be up and the other door will be down. Is this normal and did it come from the factory that way? If so which side was up and which side is down?
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I'll have to disagree with the parts house. I will look again to make sure; I think the bolt pattern wouldn't allow for upper hinge driver/passenger side swap.
Brad Wrench Fetcher, PhD | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Upper hinge: Driver's side spring/lever is on the bottom; passenger side spring/lever is on the top. My passenger side hinge has never been removed.
I actually think they may be right. The hinges' arms could be flipped and the bolts would align correctly.
My apologies to the unknown parts store.
Brad Edit- I'm just getting confused looking, but the FAM gives pn 3716441 LH, pn 3716442 RH for the upper hinge
Wrench Fetcher, PhD | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | It physically fits. I did not even use a BFH. I saw it in the tucker catalog and then I called them and verified what the catalog showed. I was told thats the way it goes. I just thought it was weird but I did not look when I took the doors apart. So it's new to me. My body guy has my assembly manual so I could not look in the book.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Jaime, I put part numbers from the FAM if that'll help. I was referring to the bolt pattern on the doors; check that out. Brad
Wrench Fetcher, PhD | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Thanks for the reply I am like you I would have never thought that. Cool you learn something new every day
