2 members (49 panel, Nick in Manitou), 22 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1122468 09/03/2015 11:02 PM
I have a 1956 Chevy 3100 and my question is... the upper door hinges are the same for both doors. I called the parts house and they said there is only one hinge for the upper and lower and there is no right side or left side hinge. If this is true the spring on each upper hinge on the one door will be up and the other door will be down. Is this normal and did it come from the factory that way? If so which side was up and which side is down?
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
U
U Offline
I'll have to disagree with the parts house.
I will look again to make sure; I think the bolt pattern wouldn't allow for upper hinge driver/passenger side swap.
Brad
Wrench Fetcher, PhD
U
U Offline
Upper hinge: Driver's side spring/lever is on the bottom; passenger side spring/lever is on the top. My passenger side hinge has never been removed.
I actually think they may be right. The hinges' arms could be flipped and the bolts would align correctly.
My apologies to the unknown parts store.
Brad
Edit- I'm just getting confused looking, but the FAM gives pn 3716441 LH, pn 3716442 RH for the upper hinge
Wrench Fetcher, PhD
It physically fits. I did not even use a BFH. I saw it in the tucker catalog and then I called them and verified what the catalog showed. I was told thats the way it goes. I just thought it was weird but I did not look when I took the doors apart. So it's new to me. My body guy has my assembly manual so I could not look in the book.
56 Chevy 3100
U
U Offline
Jaime, I put part numbers from the FAM if that'll help. I was referring to the bolt pattern on the doors; check that out.
Brad
Wrench Fetcher, PhD
Thanks for the reply I am like you I would have never thought that. Cool you learn something new every day
56 Chevy 3100
