| | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 36 Junior Member | | Junior Member Joined: Jan 2003 Posts: 36 | I have the stainless around the windows-the piece that fits on the front of the hood to clean and polish. I need to know what I should use to do this. Do I use a rubbing compoud or a wax? I am sure alot of elbow grease too | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Stainless trim that doesn't shine brightly anymore usually needs to be buffed...with a buffing wheel and appropriate buffing compounds. Check out Eastwood as they have a good supply of buffing/polishing stuff. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I watched these guys peddiling this stuff at a swap meet that they polished the bottom of soda cans with little effort to a miiror /chrome shine.Since i didnt need my pop cans polished and it was 10 bucks a bottle each for the polish and sealer i was ready to keep walking.It had to be a trick.Well the wife sez lets give it a try and while i was sure it wouldnt work at home i bought some.First i did the very hazy trim on the dash and glove box on my 51.Minor effort and i was definetly impressed with the bright shine.I read your post and rembered i just picked up 2 trim pieces for my 60 and thought id try one.I was again impressed.The stuff is called master fourmula metal gloss metal polish.Iffi get a chance tomorow ill try and post a picture.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | Autosol, also from Eastwood does a pretty nice job on both metals and plastics if they aren't too scratched. If scratched, the buffing wheels and compounds do the job. | | |
