2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#1121595 08/29/2015 8:48 PM
R and R the 4 speed in the 52 1/2 ton last weekend. Had a bearing in the trans go bad. Lots of metal in the fluid. Put in a new clutch kit from NAPA. Nice kit had everything and an alignment tool as well. Replacement trans was clean and looked to be in good shape. So in it went and off I go running errands and grinning like the idiot that just got his toy back. six days later, I hear a whirring noise as the clutch is depressed. Stopped at the light waiting my turn. It comes and goes. I think the new throw out bearing is not so good. Packaging said the bearing was lubed and sealed, so I only put a bit of grease on the shaft and the release arm tits. Did I forget something or did I just get a bad bearing? I really do not want to pull the torque tube apart and slide the tranny back out. I will of course, but I don't want to repeat any mistakes if I don't need to.
Steve H
Probably a bad throw out bearing.
I have a brand new one on my work bench which is so bad it osculates when you turn it by hand! It is not loose, and I cannot understand how it could have been made that way by accident.
The Chinese government currently has all of my personal information (due to sloppy US federal bureaucrats), so maybe the Chinese flagged my order for a bad throw out bearing.
Carl
What I was afraid of. I might let it whine for a while, but I will have to fix it some day soon
Steve H
Are you sure you have the 3/4" to 1" free play in the pedal
and your not spinning the brg all the time?
dg
Denny G
Sandwich, IL
Steve_H #1121925 08/31/2015 10:39 PM
I guess I am lucky. I got nearly 1500 miles on my new throwout bearing before it started screeching. I do have proper free play. It has gone from occasional to every time I push the clutch pedal in and the noise level has increased greatly. Very embarrassing at stoplights. I put it neutral when rolling up to a light. People in the next lane often say nice truck or give a thumbs up until I put it in gear and they hear the screech.
Going to have to fix it soon but not ready to wrestle the 4 speed by myself. It was so easy to install on a bare frame. Searching regarding this problem indicates we are not alone.
Riding in the Passing Lane
Its going to tear up the fingers on the pressure plate.
1972 Chevy c10 Cheyenne Super
