7 members (D B Cooper, 55shaker, GMCJammer51, MickeyP, ndkid275, Phak1, 1 invisible), 159 guests, and 1 robot.
Topics128,095
Posts1,056,069
Members48,433
#1121474 08/29/2015 2:18 AM
today's work was to try to remove the clutch/brake pivot shaft. There was no way that I was getting that nut off with brute strength. My bad heart will not let me strain that hard. Went to Autozone and bought a nut splitter, which worked fine for only $13 and no strain.
Now the shaft needs to come out and I'm not taking the fender off to beat on it! I start making room for it to come out buy taking my machinist hand shaft and a small round bur to grind out some space between the shaft and frame. Wiped myself working by 10 AM so will get back on it tomorrow. Will probably have to add weld to the enlarged hole or make a completely new shaft to fit.
1 Offline
Did you know that she shaft is bolted to a bracket that can be removed? Although the master cylinder also connects to that bracket I believe
Thanks, I'll look at that in the morning.Burned myself again before noon.
Thank You, Thank You, Thank You 1866yellowboy! Smart people like you know what to do and average people like me are supposed to look at the assembly manual sitting on the desk! DUH!
Not easy to get to the bolts but I got them out before noon. Now to turn a new shaft.
