| | | Forums66 Topics128,052 Posts1,055,770 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | today's work was to try to remove the clutch/brake pivot shaft. There was no way that I was getting that nut off with brute strength. My bad heart will not let me strain that hard. Went to Autozone and bought a nut splitter, which worked fine for only $13 and no strain.
Now the shaft needs to come out and I'm not taking the fender off to beat on it! I start making room for it to come out buy taking my machinist hand shaft and a small round bur to grind out some space between the shaft and frame. Wiped myself working by 10 AM so will get back on it tomorrow. Will probably have to add weld to the enlarged hole or make a completely new shaft to fit.
| | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Did you know that she shaft is bolted to a bracket that can be removed? Although the master cylinder also connects to that bracket I believe
| | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | Thanks, I'll look at that in the morning.Burned myself again before noon. | | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | Thank You, Thank You, Thank You 1866yellowboy! Smart people like you know what to do and average people like me are supposed to look at the assembly manual sitting on the desk! DUH!
Not easy to get to the bolts but I got them out before noon. Now to turn a new shaft.
