3 members (Hush, Otto Skorzeny, crenwelge), 111 guests, and 3 robots.
Topics128,077
Posts1,056,015
Members48,433
#1097985 04/17/2015 10:57 PM
Unless you are under 18 yrs. old and 128 lbs., then working under the dash is the worst job on the truck.
This is my "comfort fix tip" http://s982.photobucket.com/user/JOHNHILL_photos/library/Truck%20Dash%20bench
Someone may have done this before but it is my idea and it works great. I used a 4' piece of 3/4" plywood that I had and lay it between the floor of the truck and my shop stool with a block of wood on it to bring it up to same height as truck floor. I place a moving pad on the board and climb in. Something for a pillow would help if you are going to spend some time under there.
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
Great tip, thanks!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
A great idea that I wish I had thought of a couple of years ago.
I am still trying to uncoil and straighten up!!
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
I don't fit there to well
I have to remove the seat bottom and run the board there
John,
Great tip.
For some of us our bodies do not bend easily.
Harold
Harold
Great tip. Looks so comfortable that I might fall asleep. I appreciate the tip.
7
7 Offline
I am in the middle of a total frame off resto of my 50 3100.
I have been using my boy's old crib mattress. Its the perfect size and fit .What a back saver !
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
Love that idea. Wish I had thought of it. Thanks
Steve H
I do the same thing. Works great. I need to pull the floor shifter though. Steve
I have removed the pedals from under the cab to get in with out bruising my neck. Not a lot of room to get in there. The shop stool and a board, that is just great.
Steve H
I like it👌🏻
Changed out the heater core in my Deluxe heater this summer and
I used John's idea. A piece of 12" shelving and a horse of the
right height and it made working under the dash a whole bunch
more comfortable, almost took a nap on it when I was finished:
http://www.pbase.com/dennygraham/image/160203521
Was thinking that next time I might take a sheet of plywood
and cut a wider one that fits the whole width of the door
opening. Then I can roll around without fear of falling
off the edge.
Update: On my way out to the barn to cut some wood.
http://www.pbase.com/dennygraham/image/161172149
dg
Denny G
Sandwich, IL
Hey John, you live in that farm house back in the woods along
the creek or in that palatial mansion up front????
Sure is pretty country down there. My wife grew up down in
Rockingham, still has relatives in Gelead, we don't get
down to visit often enough.
Thanks for the tip, that was a pleasure....almost....working under the dash this time.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks for sharing! I'll use it!
1955 GMC 100 Short Bed Step Side
248ci with 12 volt conversion and 6 volt electronics
U
U Offline
5 star idea there 7998 & I have a crib mattress (maybe I can sneak out & use). We just upgraded to a twin-size mattress for my son.
I was about to complain about fiddling with the headlight switch wiring last night--- without a seat installed... Thanks for the drawing picture Denny; my seat won't be out forever & I'll put the plan to use.
Brad
Wrench Fetcher, PhD
Moderated by  ndkid275, Phak1
