0 members (), 116 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
This is my first time with a dually. I have a '55 6400 2nd series truck. I have 5 studs on the rear wheel hubs. I have 10-hole rims that are hub piloted.
I have seen setups where there is an inner lug nut on the first rim and then an outer lug nut on the second rim. However, the second rim had larger mounting holes.
All my rims have the same size mounting holes (~5/8" diam.). Do I mount both rims and then use one lugnut? What am I missing? What kind of lugnut do I use? Plain nut, with a flange?
1955 Chevy 6400 2-Ton
LewyBoys' Garage
It might help if you post a picture of the wheels in question on your photobucket page so we see what your looking at.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
These are not Budd wheels, one nut holds both wheels on, some have retainer rings that cover the bolt circle, then put the lug bolts on.
Sir Searchalot
Sir Searchalot
This can only be answered by "Lugnuts".
I suspect your have 10 lugs on 7.25" bolt circle.
For that vintage they most commonly had a "clamp plate or ring" as Ed mentioned and then the lug nuts hold everything together, the wheels are piloted snugly on the hub.
Here is a picture of what that looks like.
Also in the picture is a newer lug nut with a large washer face often used without the clamp plate. My opinion is if the wheels/truck was supposed to use clamp plates then you ought to continue to use them.
https://picasaweb.google.com/lh/photo/SlJJGfds_gFZpL2YoQzTNdMTjNZETYmyPJy0liipFm0?feat=directlink
Also notice the nuts have little slots in them, a sort of lock nut. That particular style is called a "Marsden" nut and I've seen them as original equipment on many of these old trucks. Not sure when they stopped using them as lug nuts. http://www.lok-mor.com/products/marsden.htm
•1952 Chevrolet 3800 pickup
---All pictures---
I have uploaded a few photos in my bucket to better show what I have. I have two rims mounted to the back axle. You can see that only the lugnut will fit. I do not think I could fit a clamp plate underneath. The side view of the rims shows that they are two different widths - not sure why. Finally you can see a picture of the wheel hub without rims and the two different lugnuts I have - one flanged, one Marsden.
Once the rims are cleaned up, should I be able to mount the two rims without a clamp plate?
New photobucket images
LewyBoys' Garage
Steve,Sure LOOKS like the '56 6400 frame that you trailered from Iowa,from the looks of the rear cross-member area. That one HAD 6-bolt RH5's. Your rear hubs,(5-hole wheels),SHOULD be 10-bolt. Rims should match,since you don't want the sidewalls of the tires to rub. "We" have about 8 good 3-piece rims,5-hole,10-bolt), still available,if you need any. What happened to your springs??
Mo' Tater
If the bolts are too short, it is easy to take the hubs off and install new, longer, non-rusty lug bolts.
This is the frame from Iowa! I got rid of the RH5s because of the bad reputation. I have 6 rims right now but will let you know if I need to replace any of them. I have the springs from the frame off right now to clean up and paint. I will post some pictures of the frame soon comparing it to the original state!
LewyBoys' Garage
Hey,Steve! Glad to see you're making some progress. My'55 2nd-Series didn't use a clamp plate. That's probably why they were 10-lug. My friend's '59 viking 60 bus,uses both flanged,(outside),and Marsden,(inside),and a clamp ring,but his are 6-lug wheels. Passenger-side lugs are right-hand thread,as well.Please keep us posted on your progress!
Mo' Tater
