| | | Forums66 Topics128,100 Posts1,056,515 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 5 New Guy | | New Guy Joined: Aug 2012 Posts: 5 | Can anyone tell me if there were different castings, and therefore casting numbers, for the early '54 engines with the small-journal camshaft vs. later '54 235 engines with the large-journal camshaft? I have a '54 from a 3100; the block is cast "3835911" and by the look of the distributor gears, it has a forged i.e. small journal shaft, yet I see this casting number listed for the '55 1st series as well, which post dates the change to the large journal cam. Was the same casting used for both?
Scott Andrews Dacula GA 30019
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Check Here A It says something about small/large journal camshaft engines. Not sure if engine cast number will tell you what size the camshaft journals are used in the engine. Check Here B Group number 0.519 camshafts Scroll down page you will see bearings. Bearings continue on next page. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have found sources listing these block casting codes for
1954 truck 235: 3701481 3702436 3835911 (supposedly also used in Corvette 235 in 1954 & 1955) 3701488 listed in one source
1955-1st truck 235: 3733949
1955-2nd truck 235: 3836233 (used again in 1956) | | |
