15 members (Jims46, Southerntruck, joe apple, Otto Skorzeny, Hawkman, J Lucas, D B Cooper, Oldcaliforniakid, Stovebolt48, Bill Hanlon, Peggy M, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 1 invisible),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | R and R the 4 speed in the 52 1/2 ton last weekend. Had a bearing in the trans go bad. Lots of metal in the fluid. Put in a new clutch kit from NAPA. Nice kit had everything and an alignment tool as well. Replacement trans was clean and looked to be in good shape. So in it went and off I go running errands and grinning like the idiot that just got his toy back. six days later, I hear a whirring noise as the clutch is depressed. Stopped at the light waiting my turn. It comes and goes. I think the new throw out bearing is not so good. Packaging said the bearing was lubed and sealed, so I only put a bit of grease on the shaft and the release arm tits. Did I forget something or did I just get a bad bearing? I really do not want to pull the torque tube apart and slide the tranny back out. I will of course, but I don't want to repeat any mistakes if I don't need to.
Steve H
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Probably a bad throw out bearing. I have a brand new one on my work bench which is so bad it osculates when you turn it by hand! It is not loose, and I cannot understand how it could have been made that way by accident. The Chinese government currently has all of my personal information (due to sloppy US federal bureaucrats), so maybe the Chinese flagged my order for a bad throw out bearing. Carl
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | What I was afraid of. I might let it whine for a while, but I will have to fix it some day soon
Steve H
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Are you sure you have the 3/4" to 1" free play in the pedal and your not spinning the brg all the time?
dg
Denny G Sandwich, IL
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I guess I am lucky. I got nearly 1500 miles on my new throwout bearing before it started screeching. I do have proper free play. It has gone from occasional to every time I push the clutch pedal in and the noise level has increased greatly. Very embarrassing at stoplights. I put it neutral when rolling up to a light. People in the next lane often say nice truck or give a thumbs up until I put it in gear and they hear the screech. Going to have to fix it soon but not ready to wrestle the 4 speed by myself. It was so easy to install on a bare frame. Searching regarding this problem indicates we are not alone. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its going to tear up the fingers on the pressure plate. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
