2 members (baldeagle, Shardean),
31
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 83 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 83 | I have a '49 Chevy 4400 with a standard cab, I have seen a '48 GMC 3200 5 window cab and front clip for sale. Wondering if the '48 GMC cab is the same size and a direct swap for the '49 Chevy standard cab?
Thanks in advance. Kevin | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 48 GMC 3200 ? If made in USA GMC trucks were 100, 150, 250, 280, 300, 350, 400, 450, 470 series etc. Never heard odf a 3200 series GMC. | | | | | Joined: Mar 2002 Posts: 83 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 83 | Sorry.... Let me put it another way.. will a 48 GMC half ton cab swap with a 49 Chevy 1 1/2 ton cab?
Thanks, | | | | | Joined: Mar 2002 Posts: 83 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 83 | Doing a better job of searching through the archives I found a couple of threads talking about this and it should work. If I had a 2 ton cab that would be a different story.
Thanks for listening.... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 2 ton cab is the same story | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I think the radiator will be in front of the core support on the GMC, so, make sure to get all the 'tin' pieces. You will also have a few more inches fan to radiator clearance-room to install a GMC engine.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | As was mentioned, the cabs themselves are the same, whether a pickup or a big truck. It's the other parts (fenders, grilles, etc.) that would be different. | | |
