4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
I have a '49 Chevy 4400 with a standard cab, I have seen a '48 GMC 3200 5 window cab and front clip for sale. Wondering if the '48 GMC cab is the same size and a direct swap for the '49 Chevy standard cab?
Thanks in advance.
48 GMC 3200 ? If made in USA GMC trucks were 100, 150, 250, 280, 300, 350, 400, 450, 470 series etc. Never heard odf a 3200 series GMC.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Sorry....
Let me put it another way..
will a 48 GMC half ton cab swap with a 49 Chevy 1 1/2 ton cab?
Doing a better job of searching through the archives I found a couple of threads talking about this and it should work. If I had a 2 ton cab that would be a different story.
Thanks for listening....
2 ton cab is the same story
1952 Chevrolet 3800 pickup
---All pictures---
Crusing in the Passing Lane
I think the radiator will be in front of the core support on the GMC, so, make sure to get all the 'tin' pieces. You will also have a few more inches fan to radiator clearance-room to install a GMC engine.
R Online: Content
As was mentioned, the cabs themselves are the same, whether a pickup or a big truck. It's the other parts (fenders, grilles, etc.) that would be different.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
While it may or may not apply here due to the larger series of trucks and the years there are a couple things to check because they are on a running change period.
Cab mounting changed in mid-49 from center shackle to the corner style.
https://www.flickr.com/photos/advance-design_parts_co/16624509183/in/album-72157651722976780/
https://www.flickr.com/photos/advance-design_parts_co/12315088635/in/album-72157640522200463/
This change requires some modification and the parts need to be part of the deal.
Structurally this same change has the cabs very different from a construction standpoint. The change above and the relocation of the fuel tank sees substantial difference in the interior sheet metal. If you have the external fuel tank it is a non issue.
https://www.flickr.com/photos/advance-design_parts_co/17058544799/in/album-72157651718017649/
https://www.flickr.com/photos/advance-design_parts_co/11974011234/in/album-72157639819091033/
