1 members (2-Ton),
167
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | The driver side has a chrome T-handle for the door lock. When I ordered a new handle, it came with out the attaching screw and, I presume, a spacer (under the screw head). Are these available anywhere?
Bob
BobS46
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bob, is your like my 37? If so the T handle will have a square hole to fit on the lock stem. The trick is to take your T handle to Ace Hardware and find one that is the right size for the stem and that will recess into the T-handle.
...haven't had mine out in years but that's what I remember. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Those "T" handles come in two different size bases. The trick is to find the correct size one to fit the latch in your truck.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | The handle seems to fit. It goes onto the square shaft OK, but bottoms on the interior door skin. But, If I screw it down tight, it will bind on the door skin. I don't know what was originally on the truck. additionally, I was hoping that there was a screw that would provide a finished look similar to that of the door handle.
BobS46
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | So what your are saying is that the shaft for the "T" handle is too short. If it was longer, the handle would hit the end of the shaft before it hits the door. Are you working with the stock inside door skin - no upholstery? I would possibly fill the "T" handle with a little JB Weld, re-drill the screw hole and see if that would move it out form the interior door surface by hitting the JB Weld before the handle hits the door.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | That is a good description of it. I might just have to try your idea. Thanks. Bob
BobS46
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | can you file some off the base of the t handle to make it shorter | | |
