1 members (baldeagle), 106 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#1119542 08/17/2015 8:06 PM
After grinding, drilling and pounding for what seemed like hours I final got the draglink ball out, I had planned to use the newer setup with the adjustable tie-rods. Now that I have it out it does not looked tapered on the inside? Is this right or do i have to have it filled & drilled to the correct angle?
http://i1062.photobucket.com/albums...3-443F-8FD8-582A4C694A83_zpsthmermsk.jpg
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
Blind1968 #1119550 08/17/2015 9:03 PM
Riding in the Passing Lane
They are straight. The new style coversion tie rod ends will fit the way they are.
1972 Chevy c10 Cheyenne Super
Blind1968 #1119556 08/17/2015 9:27 PM
I have not used the conversion ends.
However I assume you can also buy off the shelf tapered ends at NAPA and the like and have the arm reamed to match what you find.
http://www.speedwaymotors.com/Search?query=ball%20joint%20reamer
If I'm ever in the situation I'd surely ream the ends and use common easy to get ends.
1952 Chevrolet 3800 pickup
---All pictures---
Blind1968 #1119611 08/18/2015 3:01 AM
I used the new style on my 52 back a few years ago and they work great. Nooo problem.
I have not tried to search it but sometime ago the actual taper was listed. Maybe it was the 7 or 10% listed in Griggs link above but it really ain't that much on such a short distance.
Sometimes the good thing is we do have a choice...sometimes!
Moderated by  Dusty53
