3 members (jay d, Southerntruck, 1 invisible),
168
Mod | | | Forums66 Topics128,281 Posts1,058,464 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | After grinding, drilling and pounding for what seemed like hours I final got the draglink ball out, I had planned to use the newer setup with the adjustable tie-rods. Now that I have it out it does not looked tapered on the inside? Is this right or do i have to have it filled & drilled to the correct angle? http://i1062.photobucket.com/albums...3-443F-8FD8-582A4C694A83_zpsthmermsk.jpg | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are straight. The new style coversion tie rod ends will fit the way they are. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have not used the conversion ends. However I assume you can also buy off the shelf tapered ends at NAPA and the like and have the arm reamed to match what you find. http://www.speedwaymotors.com/Search?query=ball%20joint%20reamerIf I'm ever in the situation I'd surely ream the ends and use common easy to get ends. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | I used the new style on my 52 back a few years ago and they work great. Nooo problem.
I have not tried to search it but sometime ago the actual taper was listed. Maybe it was the 7 or 10% listed in Griggs link above but it really ain't that much on such a short distance. Sometimes the good thing is we do have a choice...sometimes!
