7 members (Wally / Montana, 49choptop, tesa, Shaffer's1950, klhansen, sron48, 1 invisible),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 33 | I am trying to remove the vent from my rear axle to clean it, but I can't seem to get it out. I have read that it screws in, but I have also read that it is pressed in. Does anyone know for sure? I tried using needle nose pliers to grab the valve underneath the vent cover and unscrew it, but there are no flats machined on it so I can't get a good grip on it. This lead me to believe that maybe it isn't screwed in. I don't think they would not make a way to grab hold of it if it needed to be unscrewed, but I don't know. Anyway, any help would be great. Thanks. | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Don't know about a 59 but for sure it screws in/out of my 52. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 33 | Thanks for the picture. That looks exactly like mine, but I don't have any flats to put a wrench on. Looks like I'll have to do some modifications to get it out. Thanks again! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Is yours plastic or steel? No hex/no threads and metal or plastic, is press fit, pry off.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 33 | It's steel.....and unfortunately still installed in my rear axle.  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | F*C, if it must come out you may as well get aggressive with it. I'd soak it with some Kroil, or 50/50 tranny fluid/diesel mix, then get a BIG pair of channel locks that you can get the grip you need on it and twist. There are replacements available....JCarter or maybe its The Filling Station. I know I've seen them listed somewhere. ...and oh, just before you start twisting hit you thumb with a hammer to get you in the mood! Let us know how it goes. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Gentle heat will release the rust holding it tight, or grind the cap off, use Easyout on the remainder after heating.
| | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | Ok, I'm trying to remove the vent on the rear axle of my 3/4 ton 1958 NAPCO. It was not doing its job. It seems to be pressed into the axle, after removing the cap, I was able to get a pair of vise-grips on it to turn it out and replace it. It turns very easy and does not turn out. I was able to free up the vent hole, but the cap was destroyed on removal. I tried to pull and pry it (grip it with vise grips and pry) out with no success. I could re-grip it and try to drill it out, but am not thrilled with this approach. Any suggestions? | | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | When replacing go to some other type from a vendor other than old truck parts. I'd get things with no way to turn them?
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | I bought a vent assembly from local vendor, its an Alemite 304810. Plan to carefully remove the cap from the vent tube and re-crimp it on the free-spinning vent tube still in the axle. Still unknown how this tube is secured in the axle, it is definitely not threaded!
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You don't have to remove it to clean. With the cap off, run a wire, rod or punch through the hole, using larger diameter until the tube is clear. Replace the cap. If the cap is not usable, make one from tubing just larger than the vent. Pinch one end shut and crimp the other end around the body. Crimp should leave the sides open, leaving room for the air to vent. If you feel the need to remove one pressed in, heat the axle housing with a torch. This should expand the housing and break the seal. If you need a replacement, go to www.McMaster.com/vents
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | I left the vent stud in the axle, cleaned it out and used a cap from an Alemite 304810. Used a crimp tool for cable TV ends to crimp the new cap edge over the old Chevy vent!!! Looks almost original. | | |
