1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | A while back I swapped out the mopar hot water heater my 36 came with from previous owner, with a 36 Harrison hot water heater and when I started the truck up it was spitting out coolant. Anyone know who repairs these? Send it out to someone. It looks like something in the realm of old school radiator shop territory but I have a feeling if I brought it to a local rad shop they would look at me like I brought in an alien. While I'm here, what's the best way to run it with no heater? Loop a hose from inlet to outlet on block (although hose looks like it will pinch) or plugs? Or hook back up the old mopar Thanks for any input. Christian | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sure Christian, just loop it if you want, or plug it with pipe plugs. Can't imagine needing a heater very often in San Diego though. Any shop that can do radiator repair could do the core, it's just a radiator in miniature. Problem is finding a radiator shop that repairs them, most now days are only swap shops. dg
Denny G Sandwich, IL
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Check with local car clubs or at car shows. They'll know who to trust. Most likely someone in this forum will give a reference.
Ed
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Depends on your local rad shop. Ours is run by an old timer who does excellent work and actually appreciates seeing these old rads come in. | | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | Thanks for your input everyone. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Christian s - Put a picture of it on here would you. | | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | As soon as I figure how to link a picture. What part do you want a picture of? Christian | | |
