| | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I have a 53 Chevy truck and I installed the cab but I didn't notice if there is any forward or aft adjustments on the cab . Can the cab moved front or back some or does it sit in one spot . Kinda worried when I put the bed on if it he bed wall will be to close to the cab ? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It really does not have that adjustment by factory design. I would have to go measure the distance but there is enough if both are mounted correctly they do not make contact. | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Well when I drop the cab the bolts had to be perfectly lined up didn't seem like there was no movement in either direction . Just seems like the holes in the frame for the bed seem close to cab . | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Sal, My cab and bed with all original rebuilt mounts measures 1-3/16" at the narrowest point (middle of cab). I have never had the two surfaces contact. | | |
