Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (GMCJammer51), 250 guests, and 1 robot.
Topics128,290
Posts1,058,566
Members48,492
#1118744 08/12/2015 10:35 PM
Anyone found suitable front tapered wheel bearings for a 1-ton (1949)?
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
Not availible. Used to be able to get Tapered for 52 and up spindles, but they aren't out there anymore either.
I did a bunch of research awhile back. The inner bearings aren't really a big deal to find tapereds, but GM used an oddball on the outer.
There's nothing really wrong with the OE style ball bearings. They actually roll easier and take misalignment better than tapers.
Chris
1954 3600 Chevy Truck
"The Fake Truck"
Thank you Whitedog, Can you mix tapered and OE style? If so do you have a part# for the inner. My inner bearing races are grooved pretty good.
Nope, can't mix n match bearings. It has to do with harmonics, pre-load, etc...
Here's what you need.
http://www.classicparts.com/1936-52-Wheel-Bearing-3_4t-Frt-Inner/productinfo/73-021/
http://www.classicparts.com/1936-52-Wheel-Bearing-3_4t-Frt-Outer/productinfo/73-051/
Some other vendors have them too. Get ready to open your wallet.
"The Fake Truck"
Moderated by  Dusty53
