| | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Anyone found suitable front tapered wheel bearings for a 1-ton (1949)? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Not availible. Used to be able to get Tapered for 52 and up spindles, but they aren't out there anymore either.
I did a bunch of research awhile back. The inner bearings aren't really a big deal to find tapereds, but GM used an oddball on the outer.
There's nothing really wrong with the OE style ball bearings. They actually roll easier and take misalignment better than tapers.
Chris | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Thank you Whitedog, Can you mix tapered and OE style? If so do you have a part# for the inner. My inner bearing races are grooved pretty good. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | |
