6 members (3B, HandyAndy, dt235sd, Gdads51, Joe H, DennisM), 122 guests, and 0 robots.
Topics128,049
Posts1,055,693
#1116529 07/31/2015 12:46 AM
Started to adj. my rear brakes, then I remembered that I had changed rear ends and now have a Monte Carlo rear end from a 76. It has self adj., so no hole, so can I jack up the rear, start the truck, put in reverse and just start hitting the brake to adj? Or do I have to drive it in reverse to make the adj. work? 53 3100 root
root #1116535 07/31/2015 1:30 AM
Root, I don't have the "scientific data" to back me up but I think it'd be a lot better doing it under actual conditions with the weight and wheels on the ground. Find a big parking lot, wally world?, or a nice country road or down at the end of your street. Just my opinion.
...are you sure about no holes? As far as I can remember the self adjusters I've seen have holes. Are your plugged an your just missing the holes? I have a 79 Malibu under my 37 and it has he holes.
root #1116565 07/31/2015 2:53 AM
You can jack up the rear end, have someone step on the brake pedal while you turn the tire backward by hand. It won't go anywhere, but you should here the adjuster click every time you try to turn it. When it quits clicking, you are done.
root #1116698 07/31/2015 9:29 PM
I believe the stock drums had a punch out slot but you have to remove the wheels to get to it. If they are aftermarket drums, probably not. I think they stopped having a slot in the backing plate in the late 60's depending on the vehicle.
fred
root #1116846 08/01/2015 9:07 PM
Riding in the Passing Lane
If the brakes aren't adjusting in normal use, pull the wheels & drums & free up the sdjusters. Click them up till the drum goes on with very little play or drag. Some drums & some backing plates have a knock out slot to adjust or back off the shoes.
1972 Chevy c10 Cheyenne Super
root #1116847 08/01/2015 9:13 PM
I am going to take the drums off an adj, that way I know what I have. Will look for a knock plug when I get the drum off, looking from the out side there is no plug. thanks for the help. root
root #1117097 08/03/2015 2:35 AM
Took the drums off today,boy where they a long way off. Turn the star about 1 1/2 full rev. checked the adj. it seems to be working,but would have taken a lot of backing up. Will take for a test drive tomorrow. root
