0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1116067 07/28/2015 3:46 AM
Trying to remove bed in sections got all bolts out swung passenger side panel out from front panel but the rear side panel seems to be welded or spot welded to the lower sheet metal or rusted frozen. anybody ever run into this? I thought you could remove the bed in sections on this truck or is that not true for a 55.1?
Not very familiar with the 55.1 but I think you are correct in believing the its all panels. It is not uncommon to find all sorts of things welded or bolted to these trucks. Take a close look and determine what it is. A good grinder or cut off wheel can slice through the welds so you can get it apart. Let us know what you find.
It'd be nice to check out the online manuals and review the assembly manual. They sure come in handy for lots of things.
http://chevy.oldcarmanualproject.com/
Subvet,
Im not sure about removing in sections either but I have a 55.1 and can inspect mine and see if it is the same as yours. Maybe that will give you a good idea where to start.
Post a link to some pics if you want me to take a peak at mine for you.
Danny
1955.1 Chevy 5 window 3100
Instagram - @1955.1chevy
If you are talking about the rear cross sill to rear pocket,
then yes, they were welded. This was also done on the
earlier beds.
http://www.pbase.com/dennygraham/image/160865707
dg
Denny G
Sandwich, IL
Thanks Denny that is exactly what I was looking for mine is just like that. I guess I will just slide the sides off with the rear sill. And yes sill is the correct term. Thanks for taking the time, now I can proceed without thinking I missed removing a bolt some where. I have a lot of rust removal to do, it would have been easier if it separated.....Thanks again big help
Harry
The only place they are welded other than the corner bed wood strip is a small vertical weld on the rear cross sill. The rest is bolted.
I might go ahead and try to cut welds.....if I have to I can re weld
Many people do not weld on re-assembly. That allows you to paint the parts before assembly and eliminate a spot where rust will form at the welds. Unless you plan to do some heavy hauling the bed side will not be likely to move. To make it even more secure you can bolt it exactly where you want it then drill the bolt holes one at a time for a 3/8 bolt instead of 5/16.
Mar-Ktech
