2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#1115754 07/26/2015 7:52 AM
Does anyone know the length of the rear axle u-bolt's on a 1949 1-ton with the helper springs?
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
They are just under 12" looks to be 11 7/8".
http://s1142.photobucket.com/user/52_Ton/media/Suspension/IMG_2152.jpg.html?sort=3&o=0
Mine is a 52 pick up and would assume would be the same??
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
Thank You!
Better double check on your axle and springs before ordering some.
Not uncommon for leaves to be added or even removed over time. Then u-bolts should be replaced if ever removed, may not be original either.
U-bolts in my mind are an item that you measure and purchase to fit the situation, not to try and match any one else's truck. Too many possibilities and variations exist.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I measured from the top side down while standing upright. My truck has the original spring configuration. But as Grigg says better safe than sorry.
Mark
Moderated by  Dusty53
