| | | Forums66 Topics128,283 Posts1,058,519 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | Does anyone know the length of the rear axle u-bolt's on a 1949 1-ton with the helper springs? Thanks | | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Better double check on your axle and springs before ordering some. Not uncommon for leaves to be added or even removed over time. Then u-bolts should be replaced if ever removed, may not be original either.
U-bolts in my mind are an item that you measure and purchase to fit the situation, not to try and match any one else's truck. Too many possibilities and variations exist.
Grigg | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | I measured from the top side down while standing upright. My truck has the original spring configuration. But as Grigg says better safe than sorry.
Mark | | |
