| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 208 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 208 | So I am looking at a few different engines to put into my 1949 1-ton. I have it narrowed down to a 292 or a 350. I know either way I will have to do some modifications (engine cradle for sure on both). I have the cradle ready to go in just waiting on my decision on the engine. My first question is how will I know where to bolt up the cradle on the frame and secondly at what angle should the engine set? Lastly if I went with the 292 and used a early 70's SM465 4-speed transmission will the stock transmission crossmember still be used or will I need a aftermarket transmission cradle? | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Cradle placement will depend on several items that you choose. Angle is best to set to match pinion angles on rear differential or as close as possible. If the rear is 4deg up then engine usually is 4 down. (straight line setting).
After considering pinion angle, level heads are next desired. forward/rear placement is space available. Basically clearance for 350s distributor and in the front fan blades and room for fan shroud. You can not do much to adjust rear clearance on the 350 but you can do mod on the front to gain space.
Side to side centered is first choice but some left or right shift to clear obstacles (I E steering). Choice of exhaust will also help here with early chevy rams horn exhaust being the tightest.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You definitely don't want your transmission output and the pinion to be in a perfectly straight line. I believe there is a Tech Tip on this.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 292 would be easier as you will not have clearance problems with the steering gear. It will look more natural. The V-8 will run better. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I didn't think a 292 was an easy swap/ replacement for 235. What is required to make it work?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It's not a bolt in swap but it is easier then the 350 V-8. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
