4 members (Gray_Ghost, DadsFirstPickup, TUTS 59, 1 invisible), 71 guests, and 4 robots.
Topics128,089
Posts1,056,364
Members48,442
#1115285 07/23/2015 3:19 PM
Guys,
I've been told I can swap the drum/hub/backplate assembly from a 51-54 Chevy passenger car with my 52 3100 in order to get a 5x4.75 bolt pattern. Does anyone know if the assemblies from the rear of the car will fit on the front of my truck? Thx
1952 Chevy 3100
Semper Fi !
All you need for the front is use the 1951-54 pass drums and front hubs, the brakes are the same so no need to touch those.
On the rear you will need to change the diff or re-drill the axles.
My Blog
I did a rearend swap on my 52 so I'm good to go there. I'm looking for something for the front of my truck. I found a 51 Styleline in a local junkyard but it only has the rear hubs/drums on it. Will those fit on the front of my truck?
1952 Chevy 3100
Semper Fi !
Drums will work, but the rear does not have hubs, just axles. You need front hubs.
My Blog
Ah. Thx for clearing that up Dave. I'll keep looking for front hubs
1952 Chevy 3100
Semper Fi !
