| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | Guys, I've been told I can swap the drum/hub/backplate assembly from a 51-54 Chevy passenger car with my 52 3100 in order to get a 5x4.75 bolt pattern. Does anyone know if the assemblies from the rear of the car will fit on the front of my truck? Thx
1952 Chevy 3100 Semper Fi !
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All you need for the front is use the 1951-54 pass drums and front hubs, the brakes are the same so no need to touch those. On the rear you will need to change the diff or re-drill the axles.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | I did a rearend swap on my 52 so I'm good to go there. I'm looking for something for the front of my truck. I found a 51 Styleline in a local junkyard but it only has the rear hubs/drums on it. Will those fit on the front of my truck?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Drums will work, but the rear does not have hubs, just axles. You need front hubs.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | Ah. Thx for clearing that up Dave. I'll keep looking for front hubs
