5 members (55shaker, Charles in CA, JW51, Southerntruck, Gray_Ghost), 100 guests, and 1 robot.
Topics128,052
Posts1,055,725
#1113140 07/11/2015 10:32 PM
Something just ain't right. Took my truck to the store and back home the other day. About 10 miles one way. My 1949 has a 235- 1955 engine in it. It has an oil filter on it. The gauge reads 0-30 pounds. When it cranks up it will hold around 15#. On the way back it was dropping and when I would let off the gas it would go back to 15#. Then it keep dropping, let off the gas-no good. By the time I got home I had 0(zero) pressure. I think I'm running 30 weight oil (not for sure but pretty sure) Could I possibly need a new oil pump. Or maybe something else? I thank you in advance and will try what ever you come up with. Thanks for listening. Oh, it makes no sound, like knocking or clattering when the pressure is on 0 (zero) When I check the oil it is always full. Thanks so much for any help you may have. Steven (Stock engine)
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Red 49 Truck #1113141 07/11/2015 10:35 PM
What kind of oil filter do you have on it?
Red 49 Truck #1113145 07/11/2015 10:54 PM
I have an orange one with the black top, I think it's a canister. It mounts on the manifold
Red 49 Truck #1113149 07/11/2015 11:08 PM
It sounds like you've got enough bearing wear that the oil pump can't keep up with the leakdown rate. Drop the oil pan and inspect the bearings, measure the crankshaft for size and roundness, and check the clearance with Plastigauge. In 50-something years of fixing cars, I've only seen two oil pump failures that resulted in low/no oil pressure, and both of them had a piece of debris in the relief valve.
Red 49 Truck #1113156 07/11/2015 11:39 PM
Jerry, boy that is not what I wanted to hear but you have to do what you have to do. Looks like I have some work to do. Thanks a million. Good to hear from you. Did you say you were interested in the 1956 235 engine I took out of my truck. Seems to me you did. I've had it all these years and I don't think I'll be using it. Send me a PM if you are. Take care, Steven
Red 49 Truck #1113167 07/12/2015 12:58 AM
Red49Truck, have you tried another oil pressure gauge hooked to the engine?
Steven, just sent you a PM. Thanks!
I have tried another gauge but it came with the truck when I bought it. Might be good to "lick that calf again." Thanks everyone. Steven
Jerry, I sent you a PM back. Thanks
