7 members (Charles in CA, 32Fordpuchoptop, tclederman, 68ironhead, JW51, Shade Baby, 3B),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,648 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Something just ain't right. Took my truck to the store and back home the other day. About 10 miles one way. My 1949 has a 235- 1955 engine in it. It has an oil filter on it. The gauge reads 0-30 pounds. When it cranks up it will hold around 15#. On the way back it was dropping and when I would let off the gas it would go back to 15#. Then it keep dropping, let off the gas-no good. By the time I got home I had 0(zero) pressure. I think I'm running 30 weight oil (not for sure but pretty sure) Could I possibly need a new oil pump. Or maybe something else? I thank you in advance and will try what ever you come up with. Thanks for listening. Oh, it makes no sound, like knocking or clattering when the pressure is on 0 (zero) When I check the oil it is always full. Thanks so much for any help you may have. Steven (Stock engine) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What kind of oil filter do you have on it? | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I have an orange one with the black top, I think it's a canister. It mounts on the manifold | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | It sounds like you've got enough bearing wear that the oil pump can't keep up with the leakdown rate. Drop the oil pan and inspect the bearings, measure the crankshaft for size and roundness, and check the clearance with Plastigauge. In 50-something years of fixing cars, I've only seen two oil pump failures that resulted in low/no oil pressure, and both of them had a piece of debris in the relief valve. Jerry
| | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Jerry, boy that is not what I wanted to hear but you have to do what you have to do. Looks like I have some work to do. Thanks a million. Good to hear from you. Did you say you were interested in the 1956 235 engine I took out of my truck. Seems to me you did. I've had it all these years and I don't think I'll be using it. Send me a PM if you are. Take care, Steven | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Red49Truck, have you tried another oil pressure gauge hooked to the engine? | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Steven, just sent you a PM. Thanks! Jerry
| | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I have tried another gauge but it came with the truck when I bought it. Might be good to "lick that calf again." Thanks everyone. Steven
Jerry, I sent you a PM back. Thanks | | |
