2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | Hi Guys: My '54 235 engine is stuck. I was told the crank shaft had babbets so would not be the source of freezing due to rust. Does anyone know if this is true? Thanks! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | billm, I've had friends who had engines stuck that were Babbitt. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Babbit is simply a soft bearing material that's bonded to the big end of the rods instead of having a removable bearing. While it can't rust, the rest of the rod can. It's much more likely that the rings and/or the cast iron pistons have rust-bonded to the cylinder walls. Soak the cylinders with KROIL or some other penetrating oil, then carefully pry on the flywheel teeth with a pry bar like the chisel end of a long shepherd's crook wrecking bar. It might be necessary to remove the cylinder head and pound on the piston tops with a block of hardwood and a BFH to break them loose. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | billm,
A 1954 235 engine would have insert/removable rod bearings. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | What HRL said. I personally owned a 46 with the old Babbitt engine and the piston rings were stuck. Ended up pulling the head and doing exactly what Jerry mentioned. I burned firewood back in the mid 80's and found a stick of oak that was just the right size. Got the engine running but I guess I broke the ring when I was hitting on it. That thing smoked like a tar kettle after that! | | |
