5 members (WICruiser, GMCJammer51, Southerntruck, Phak1, NorCal52Suburban), 73 guests, and 1 robot.
Topics128,196
Posts1,057,395
Members48,471
Gentlemen,
How fast (mph) would a stock 1936 truck with original 206 engine run?
My only experience is with a 216 and 235. I can get those up to about 60-70 mph in my stock vehicles. I just want to know what to expect from a 206 motor??
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
With final drive ratio and tire rolling diameter you can calculate it based on max engine RPM.
Unless top speed is drag limited; in that case you will probably still reach top speed as long as you can find a steep enough hill...
David
https://www.google.com/?gws_rd=ssl#q=gm+heritage+1936+chevrolet+truck
Click on the first result pdf 1936.
You will find a graph saying top speed is 75.
You will also find a page that says max rpm is 3,800, and that for every 50 rpm you will go 1 mph. So 3,800/50 = 76 mph.
If, on the other hand, you are asking about a maximum sustainable speed - or a maximum economical cruising speed - the answers will be different.
75 mph will blow that sucker to smithereens fairly promptly, I think.
1951 3800
-hotshoe
Top speed is never sustainable, head winds, load changes, grade changes. And that truck was not built to run flat out all the time.
Though I think everyone may not to go that fast they still want to know what their old car, truck, motorcycle, can do.
Yea I likely won't push it to go 70mph.
maybe 50-60 tops on the highway. I just wanted to understand the limitations so I don't push it to hard.
Thanks!
LOS ANGELES, CA
