| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Gentlemen,
How fast (mph) would a stock 1936 truck with original 206 engine run?
My only experience is with a 216 and 235. I can get those up to about 60-70 mph in my stock vehicles. I just want to know what to expect from a 206 motor??
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
| | | | | Joined: Jan 2015 Posts: 32 New Guy | | New Guy Joined: Jan 2015 Posts: 32 | With final drive ratio and tire rolling diameter you can calculate it based on max engine RPM.
Unless top speed is drag limited; in that case you will probably still reach top speed as long as you can find a steep enough hill...
Thanks, David
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | If, on the other hand, you are asking about a maximum sustainable speed - or a maximum economical cruising speed - the answers will be different.
75 mph will blow that sucker to smithereens fairly promptly, I think.
1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | If, on the other hand, you are asking about a maximum sustainable speed - or a maximum economical cruising speed - the answers will be different.
75 mph will blow that sucker to smithereens fairly promptly, I think. Top speed is never sustainable, head winds, load changes, grade changes. And that truck was not built to run flat out all the time. Though I think everyone may not to go that fast they still want to know what their old car, truck, motorcycle, can do. | | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Yea I likely won't push it to go 70mph. maybe 50-60 tops on the highway. I just wanted to understand the limitations so I don't push it to hard.
Thanks!
LOS ANGELES, CA
