3 members (Roy Rodgers, elhippie64, 1 invisible), 76 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#1113199 07/12/2015 2:44 AM
Hi Guys: My '54 235 engine is stuck. I was told the crank shaft had babbets so would not be the source of freezing due to rust. Does anyone know if this is true?
Thanks!
billm #1113200 07/12/2015 2:47 AM
billm, I've had friends who had engines stuck that were Babbitt.
billm #1113202 07/12/2015 2:55 AM
Babbit is simply a soft bearing material that's bonded to the big end of the rods instead of having a removable bearing. While it can't rust, the rest of the rod can. It's much more likely that the rings and/or the cast iron pistons have rust-bonded to the cylinder walls. Soak the cylinders with KROIL or some other penetrating oil, then carefully pry on the flywheel teeth with a pry bar like the chisel end of a long shepherd's crook wrecking bar. It might be necessary to remove the cylinder head and pound on the piston tops with a block of hardwood and a BFH to break them loose.
billm #1113205 07/12/2015 2:59 AM
billm,
A 1954 235 engine would have insert/removable rod bearings.
billm #1113385 07/13/2015 2:45 AM
What HRL said. I personally owned a 46 with the old Babbitt engine and the piston rings were stuck. Ended up pulling the head and doing exactly what Jerry mentioned. I burned firewood back in the mid 80's and found a stick of oak that was just the right size. Got the engine running but I guess I broke the ring when I was hitting on it. That thing smoked like a tar kettle after that!
