| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Hello All,
Is there anyway to authenticate that a 58/59 truck was built at the factory with a fleetside bed?
Was the drivers side peep mirror included on fleetside trucks with the in-bed spare tire carrier?
There is a trim code in the color bulletin no31 page 5 - J or K for two tone paints. Is there any other?
Thanks in advance | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Thanks Builder, not checking a particular truck just a general question.
That raises another question, what vin code would tell you if it was a fleetside?
I checked 3A-3L none came back as a fleetside. | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there is no VIN indication for fleet vs step, just the 31 and 32 difference ... the 'peep mirror' was an extra cost option
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Off topic: It is good to see a post from you, Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | thnx Tim, distraction while the paint dries  I should add that the only indicator of difference fleet/step is in the model number, 3104 [3204 & 3604] for the step as previous years, 3134 [3234 & 3634] for the fleet, but I don't think you'd find that anyplace unless you have an original invoice or it shows on a title Bill | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Glad to see you back Bill.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Thanks Bill! Hope all is well! | | |
