2 members (DIY.MechanicMike, Stovebolt48), 102 guests, and 3 robots.
Topics128,179
Posts1,057,064
Members48,460
#1110713 06/29/2015 5:44 AM
Hey guys. I need your help. I bought a 1948 Chevy 1 ton in December. The guy didn't know much about it but told me it was a dump truck. It has a longbed on it and a giant hydraulic dump underneath. I can't find any others like this, so I was wondering if it is very rare or custom built? I'll try to post some pictures soon. Thanks! (P.S. it also has some other goodies that I can't figure out, like something that looks like a spotlight base on the roof?)
Also the gas filler cap is on the driver's side? It is in some riveted on panel and I checked the passenger side but it seems filler free. What's up with this?
Post the vin number then the model can be figured out.
Neverdone
Unregistered
Neverdone
Unregistered
Was a picture posted ?? If it was it is gone now
Dan
In 1947 and 1948, the fuel tank was not in the cab (it was between the frame rails in the rear - under the bed).
Here are locations of serial numbers.
It is likely it was built under the bed or between the frame rails. But with the dump hydraulics it is possible it was moved behind the seat for space purposes.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
The vin is 21FSC1667
http://s300.photobucket.com/user/Bryce_Sheedy/library/Mobile%20Uploads
Here is an album with the best pictures I could find. I am not home right now but I will post some better and more detailed pics when I return on Tuesday.
The Vehicle Serial Number
1948 truck
21 = Janesville, Wisc plant
FS = 3800 = 1 ton
C = month assembled = March
Thanks for the help with the vin, but I am still wondering if it the bed was swapped from a dump box to a longbed? Did they make trucks like this in the factory?
One size bed was available on a 1-ton truck. You can find specs at the link I gave above:
http://chevy.oldcarmanualproject.com/chevyresto/4869.htm
A dump box was not available from a GM factory. A dealer/buyer could send a cab/frame to dump box supplier.
I note the running boards are the short ones as would come with a cab and chassis, not a pickup. It looks like they were that way to start with, not shortened after the fact.
My guess is one of three posibilities...
Sold as a flat bed dump and later, perhaps much later a pickup bed installed.
Or pickup originally and early or later it was made to a dump bed, running boards were changed.
Could have been ordered as a cab and chassis and assembled with a dump mechanism and a new pickup bed when about new.
Certainly there are other possibilities too. Coming as it is now from the factory new was not one of them. Could have left the dealer or upfitter as it is now though.
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks for all your help guys! It looks like a professional job, not some average Joe slapping a longbox on. Thanks again.
The guy I bought my '48 3800 (with dump box) said his great uncle or whoever bought the PU in Montana and it came to the dealership with NO box and the rear fenders strapped to the frame. The dealership supplied an aftermarket box, dual cylinders, belt driven engine mounted hydraulic pump.
I was told that many companies offered/sold small dump boxes for pickups in that era. My box is shorter than the 9' bed and has a faded, unreadable metal tag riveted to the LF corner of the box.
The hydraulics on mine were installed after market I would guess by the farmer that owned it. I did however find a flyer on the actual Anthony Hoist system thats now on my truck.
http://i1062.photobucket.com/albums/t492/Blind9078/T2eC16VysE9sy0iOwqBRI9FQkY5Q60_57_zpsfz3dwtcm.jpg
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
This information on sources for hydraulics would have been found in the Silver and Gold books. See examples below:
1948 Issue:
https://www.flickr.com/photos/advance-design_parts_co/16736434779/in/album-72157631872034068/
1954 Issue:
https://www.flickr.com/photos/advance-design_parts_co/16708704180/in/album-72157631872034068/
1954 Hydraulic page (several options):
https://www.flickr.com/photos/advance-design_parts_co/16894892712/in/album-72157631872034068/
These books contained sources for bodies, fire trucks, all specialized applications that a dealer could use to source customer options.
Moderated by  Dusty53
