try this
first then there was
this and you'll apparently want some of
these (bottom of pg)?
Those are a few I just gobiducked...
I remember reading someone saying the regulator has to be cocked to a 15* angle or something like that and for sure have your own templates made and glass cut as the corners are quite different from original ones..
I'd rob a junk yard for spare window track and build my own surround using the vent channel bar as the front channel.
I don't think it's going to cure your water problem though, unless you find some rubber to use instead of fuzzies on the bottom.
There are plenty of other cars that have how to's and utubes and the technique is pretty much the same even on a studebaker.
